Will not start
132,000 MILES • 2.7L • 3 CYL • 2WD • AUTOMATIC
BREEZYONE01
I had the thermistat replaced and now the car will start then die and will not start again fuel pump comes on but car just won't start put brand-new sparkplugs and still nothing
Mar 23, 2022 at 9:59 AM
  • 110,244 POSTS
There is a chance the crankshaft position sensor has failed. Do me a favor, check to see if there is spark to the plugs. Here is a link that explains how it's done:
Also, take a look through this link and let me know if it mirrors what you experience.
One more test. See if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is a fuel issue. If it makes no change, then it's likely the ignition issue.
Let me know what you find.
Mar 23, 2022 at 11:46 AM
