Will not start
78,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BAUGUSBRENT
I have to turn the key off and on many many times before it will crank. I have new fuel pump, fuel filter, fuel pressure regulator. Still have to turn key off and on.
Mar 2, 2018 at 12:45 AM
  • 31,937 POSTS
when you say crank do you mean turning over on the key, or it is cranking on the key and will not run?
Mar 4, 2018 at 5:27 PM
BAUGUSBRENT
it will start after i turn the key off and on several times or let it sit for a while to let the fuel pressure build up while key is in on position.
Mar 5, 2018 at 1:50 AM
  • 31,937 POSTS
may be a failed pressure regulator, put a pressure gauge on the fuel line, see what the rail pressure is and how long it takes to bleed off, if pump pressure is very low, replace the pump and filter.
Mar 5, 2018 at 4:31 PM
BAUGUSBRENT
I guess i need to get a pressure gauge. I have replaced pressure reg. , pump and filter. Still losing pressure. Where is a good starting point to look for pressure loss?
Mar 6, 2018 at 1:28 AM
  • 55,604 POSTS
Does it run if you put starting fluid in it?
Mar 8, 2018 at 4:28 AM
