Will not start
123,000 MILES
BILLY2007314
My truck will not start only if I put starter fluid in the throttle body I changed the fuel filter and checked the timing and it is good and I have spark. I put a new map sensor on it. once I get it running it run fine
May 6, 2013 at 12:46 PM
JDL
  • 16,098 POSTS
Have you checked fuel pressure, key on engine off? Do you have the spider fuel system or TBI/throttle-body injection? With TBI you can see injector spray pattern, with the spidewr system you can't.
The spider fuel systems are generally known for problems, the fuel poppets stick.
May 7, 2013 at 2:12 AM
