Will not crank or start
80,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MIKELJ
Car will not start. will not turn over to start. changed fuel filter, new battery, charged battery. try to start with battery charger. when changing fuel filter, filter had fuel in filter. still will not start.
Dec 30, 2017 at 5:19 AM
CJ MEDEVAC
  • 11,000 POSTS
Okay,
Does nothing at all?
See my link (my answers):
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
I posted that before this other things came into being.
Many times, my link (the "get in there" motivational parts ) will be your fix.
There are other "modern car" over engineered possibilities too.
I grabbed this: "Repair guides" from the top right side of our site pages.
https://www.2carpros.com/articles
Lets scan through the list, "electrical" to "security", something may aid you in there too (even for future repairs).
I am banking on my first link answers.
Let us know how it goes
The Medic
Dec 30, 2017 at 6:16 AM
MIKELJ
Battery charge good. No corrosion or loose cables, wires. fuses good. what solenoid? EGR ? Where is solenoid you are referring to? How do I check it if it is good?
Dec 30, 2017 at 6:58 AM
CJ MEDEVAC
  • 11,000 POSTS
In ancient times, this was called the solenoid or starter solenoid. (nowadays it is often called a "starter relay")
https://shop.advanceautoparts.com/web/PartSearchCmd?storeId=10151&catalogId=10051&langId=-1&pageId=partTypeList&actionSrc=Form&searchTerm=starter%20solenoid&vehicleIdSearch=8340
You have a 5.0 Liter? (Not a 4.6)
Do you have a voltmeter or 12 volt test light?
We might be able to narrow down where the issue might be.
The Medic
Dec 30, 2017 at 7:31 AM
MIKELJ
4.6L V8. yes on volt meter.
Dec 30, 2017 at 8:55 AM
CJ MEDEVAC
  • 11,000 POSTS
Have you tried this?
See my picture.
The Medic
Dec 30, 2017 at 10:37 AM
