Will not start after replacing battery
130,000 MILES
LISA MERRIMAN
Installed a new battery and now when I try to start it, all it does is make a click noise. does not even try to start. Have all lights working.
Jul 15, 2019 at 9:55 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Hi Lisa. Honestly, the first thing I'm going to suggest is to check and make sure the battery terminals are clean and tight. Often times when you get one click, it is due to either corrosion or a loose terminal. I realize the battery is new, but are the terminals making good contact?
Let me know what you find with that and also, let me know if there were any prior issues before the battery was replaced.
Jul 15, 2019 at 1:27 PM
