Will not start
200,000 MILES
STACY2021
car was running fine, went in store came out and would not start. Battery is at full charge. Had to have car towed.
Tried to reset the anti-theft, nothing. Changed the ignition switch still nothing. I was told there was no way to scan for codes because the lights do not stay on when you leave the key in the on position. checked all ground wires they are all fine.
Sep 12, 2021 at 11:07 PM
MASTER ASE TECH
  • 82 POSTS
Hi, I'm Dan.
When you say wont start, do you mean the engine wont turn, like a dead battery? Any clicks or anything when you try to start it? You can still check for codes even if the lights go off or it wont start. Is the anti-theft light flashing at all? (looks like a red key)
Here are a couple guides that will help with this issue.
Please run through this info and let us know what you find. Thanks
Sep 13, 2021 at 1:28 AM
STACY2021
The car doesn’t make any noise at all when you try to start. There is also no power going to the port that you plug in the scanner. Anti theft call me on then right off .Headlights work as well. No power going to main fuse box.
Sep 14, 2021 at 8:04 AM
Sorry that the previous answer was not helpful. If you have no power going to the DLC then that is what we need to trace. So the fact that you have no power to the main fuse box, I assume you are talking about the one under the hood.
That would make sense with this issue because that fuse box powers the starter, fuel pump, DLC (scan tool port), and the ECM itself.
So clearly we need to stay on that and find out why you have no power coming into this fuse box. That fuse box is wired directly from the battery. Please see the wiring diagram below. The third one shows the fuse box feed from the battery.
Just to confirm this is how you are checking for power, we need to make sure you have 12 volts on this stud pictured below.
Here is a guide that will help with checking the voltage if you need it:
If you have no voltage coming in here then we have a connection issue between this fuse box and the battery.
If you do have voltage on this stud but you do not have voltage on both sides of some of the fuses then you have an issue with the circuit board on the fuse box.
However, how did you check the battery to be at full charge? Did you load check the battery or just put your meter on it and see if it had 12 volts?
It could be a battery issue even if it is showing close to 12 volts but I would suggest starting with ensuring you have 12 volts on the stud for the fuse box. If not, you may have a cable failure or the ground G109 for the fuse box which is on the left front shock tower. I know you said all grounds are fine but is the ground cable ok as well?
Let us know about this info and we can go from there. Thanks
Sep 15, 2021 at 12:52 AM
