Will not start
132,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
BOB B
  • 11 POSTS
Put a new fuel tank fuel pump and inline fuel filter not to long ago.and now my vehicle listed above (Blazer) will not start.
May 9, 2020 at 5:50 AM
  • 110,248 POSTS
Have you checked to see if it is getting fuel and spark to the engine? Chances are one is missing. Take a look through this link first.
What I want you to try is this. See if it starts for a couple seconds and then stalls using starting fluid. If it does, then we know it is a fuel related issue. If it doesn't even try to start, the suspect ignition.
Here are two links showing how to check for ignition spark and fuel pressure. If it fails to start with starting fluid, check for spark next.
Let me know what you find.
May 9, 2020 at 2:22 PM
