Shut off while driving and will not start
104,460 MILES • 5.9L • V8 • 2WD • MANUAL
S.PARMENTER
truck shut off on way home. had it checked out was told the fuel pump took a dump. so, picked a new one up drop the tank installed the new pump put tank back in gas in it turned over no start. I was told it could be the ignition module could not find it anywhere.
Mar 1, 2022 at 1:40 PM
  • 110,251 POSTS
First, if it stalled and won't restart, chances are you either lost fuel or spark to the plugs. Here is what I want you to try: See if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is a fuel related issue.
If there is no change, check for spark at the plugs. Here is a link that shows how it's done:
As far as the ignition control module is concerned, it is integral with the powertrain control module. That is an expensive part, and why I need to know if you lost spark. Also, there is a higher likelihood that the pickup coil in the distributor failed and is much less expensive to replace.
The pick-up module is located in the distributor and will prevent you from getting spark. I attached a pic below showing it.
Do these tests and let me know the results? I don't want to point you in the wrong direction.
See pic.
Mar 2, 2022 at 11:38 AM
