I expected a better answer. The car does not start with starting fluid. Spark is good.
Jun 7, 2019 at 12:21 AM
✓Experienced Mechanic
The starting fluid lets us know if the compression and ignition timing are good. Do you hear the fuel pump running in the tank for five seconds when the key is turned on and not cranking the engine?
Jun 7, 2019 at 12:33 PM
EDWARD SEMAN
MEMBER
The car ran fine, but after I stopped it , it would not start?
Jun 8, 2019 at 12:19 AM
Okay, can you try starting fluid to see if it will run?
