This is probably an issue with your vehicle's engine's cylinder head(s) and head gasket(s). What usually happens when a vehicle overheats is the aluminum cylinder head(s) warp, causing the head gasket(s) to fail. This will cause a compression issue with the engine and not allow it to start. If you would like instruction on how to replace your vehicle's engine's head gasket(s) and fix this problem, please get back to us and let us know. We will also need to know if your vehicle has a 3.8L engine or a 4.0L engine. We have the guide for you to do this, so please get back to us either way and let us know.
Thanks,
Alex
2CarPros
Jul 19, 2019 at 5:08 AM
