Will not roll roll over, clicks in kick-panel module. Solenoid & Relays are good. Any ideas?
130,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
DMANIEZ3
I have a 1999 GMC Jimmy 4.3 Vortec. When you turn the key it doesn't roll over, all I can hear is a click in the passenger kick panel. I have checked the starter solenoid with a jumper and it is fine. After a ton of checking with a multimeter and swapping fuses and relays I found something- when I remove the 40A "ign A" fuse in the fuse panel under the hood and plug it back in, I turn the key and it fires right up and stays running. However if I shut it off and try to start a second time, it doesn't roll over and begins clicking in kick panel again. Any ideas?
Jun 6, 2015 at 11:59 PM
HMAC300
  • 48,601 POSTS
chec for a bad ignition switch or starter relay see pic.
Jun 7, 2015 at 12:55 AM
THIS IS MIKE
  • 686 POSTS
Terminal 30 at the relay should be hot all the time. I can't tell, if something wrong with fuse--fuse wiring circuit or relay. Check all three.
Jun 15, 2015 at 4:25 AM
