will not idle after putting fuel in it?
150,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
SCHAE
my car will not idle after putting fuel in it take three or four starts to keep running. it has no fault codes.
Oct 28, 2023 at 10:58 PM
  • 110,251 POSTS
How much fuse did you put in it? In other words, did you fill the tank or just add? I ask because often people overfill the fuel tank, and it causes fuel to be drawn in by the evaporative emissions system. When that happens, it can cause this.
When it does start, do you notice any gray smoke or anything from the exhaust? Are there any strong odors?
Oct 29, 2023 at 11:40 AM
SCHAE
if i put $5 or $10 in it are fill it up there no smoke are anything and no smell at all just have to start it 3 are 4 times then it runs fine only when i put gas in it that's when it will not run it will start but then it shuts off.
Oct 29, 2023 at 10:17 PM
  • 110,251 POSTS
I didn't realize it was only after adding fuel. I thought the problem started after you added fuel and has been consistent since. That was my mistake, sorry. I want you to try something. The next time you add fuel, do this to see if it changes anything.
1) Turn the ignition key from off to the run position (engine off) and count to 5.
2) Turn the key off and repeat step 1 a total of five times.
3) On the 6th cycle, see if it starts normally.
Let me know what you find.
Oct 30, 2023 at 11:24 AM
