will not go pass 10mph and 1000 rpm
108,000 MILES
JVFREE
I have a 03 2.5 altima and is been a nightmare I took it to a shop because the car would not go pass 10mph at 1000rmp so they had me replace the accelerator perdal and they also check the throttle finally they told me I needed a new ecm I order a replacement with the same part number and now the car will not start please help also replaced the cam shaft and crank position sensors
May 1, 2013 at 5:17 PM
did you have the new pcm flashed?? it will not run without flashing.
May 1, 2013 at 7:23 PM
JVFREE
How do I do that?
May 2, 2013 at 1:33 AM
