Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Electra
General
Noises
Whine
Will not go in gear
1984 BUICK ELECTRA
163,000 MILES • 2WD • AUTOMATIC
84PARKAVENUE
MEMBER
1 POST
THM2004R will make a little thump when trying to go in drive. checked fluid lever hot in idle will only whine in reverse. what could be problem?
Apr 16, 2020 at 5:45 AM
Experienced Mechanic
Good afternoon,
It sounds like the front pump is whining from lack of fluid. This noise usually sounds like a power steering noise when it is low in fluid.
What causes this is the filter is clogged in the pan and needs to be changed.
I would drop the pan and change the fluid and filter.
Apr 16, 2020 at 6:10 AM
Add image or video
Ask a new question
Engine won't start
Ignition — No Spark
