Will not crank or start
146,000 MILES
REINHOLD70
Mechanic says timing chain cover has a Coolent leak. Wants $700.00 to repair leak.
I was driving and noticed the temperature gauge going up passed halfway mark. I added a quart of water and gauge was normal, came home and later started
Car to drive a short distance Later I again tried starting it would not start.
Next morning (cooler) it started okay, and now again it will not start.
Thank you for helping.
May 25, 2022 at 7:42 AM
  • 110,248 POSTS
I'm not sure what engine you have. There is a 3.0L single overhead cam, 3.0L Dual overhead cam, and 3.4L.
The water pump is mounted to the cover, so the leak could be the pump itself or a gasket. By chance, did he identify where the leak was coming from?
As far as the no start, there is a chance the crankshaft position sensor is damaged due to the coolant getting on it. To confirm this, check for spark at the plugs. Here is a link that shows how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
May 25, 2022 at 1:26 PM
REINHOLD70
Engine, for 1997 ford taurus is 3.0L-2v Vulcan flex fuel.
#DDHG558AA
Thank you
May 25, 2022 at 2:26 PM
  • 110,248 POSTS
Okay, then what I mentioned above is correct. Did the shop indicate what on the cover is actually leaking or is it the actual cover?
May 25, 2022 at 2:50 PM
