Will not crank,
200,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
WHAYES2408
I changed the coil , distributor and rotor, and it cranked! but the wire from the battery to the alternator , arc on the AC line. I turned it off and taped it up and it will not crank back up. So I changed the Cam sensor, Crank sensor, ICM, Spark plugs wires,
Need help, I'm at a lost.
Mar 25, 2016 at 10:49 PM
WHAYES2408
I'm here
Mar 25, 2016 at 10:53 PM
HMAC300
  • 48,601 POSTS
try resetting security system if yo changed the dist a pro will have to use his scanner to sync the cam/crank sensor you won't be able to do it.
Mar 26, 2016 at 12:50 AM
