Will not crank
130,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MANDIE WIGGINS
I recently purchased this car for my daughter. I have replaced the O2 sensor, crankshaft sensor, valve cover, coils, plugs, struts, and finally the throttle position sensor. I have tried three times to relearn the throttle body with no success. Any suggestion as to how to get this car back in running condition?
Aug 16, 2019 at 11:00 PM
Good morning,
Let us start with the exact issue you have. You have replaced a lot of parts but have not stated the issue.
Does the starter turn over the motor?
Is it a crank and no start?
What testing have you done. I see the parts you replaced but what tests have been done?
Aug 16, 2019 at 11:23 PM
MANDIE WIGGINS
It will turn over. The starter is fine. The valve cover was the initial problem when I bought it but of course when placed on the scanner, it uncovered the other problems. So I fixed and replaced everything that the scanner coded wrong and now I cannot get the car to crank. It will spin over but will not crank.
Aug 16, 2019 at 11:36 PM
Okay, so it does crank over.
What were the codes? Codes rarely identify bad parts, just failed systems. A clue might be there for the reason it will not run.
Did you check fuel pressure and check for spark?
Also, compression should be checked.
Aug 16, 2019 at 11:53 PM
