Will not crank
50,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RHUMMEL73
I started my truck with key fob and let it warm up. I went to leave for work and i tried to start it and all i get is a click. all lights work radio and dash also. Any ideas??
Jan 20, 2021 at 12:40 AM
  • 110,248 POSTS
First, check to make sure the battery terminals are clean and tight. Take a look through this link:
Next, I need you to load test the battery. Here is a link that shows how to do it at home:
Do this first and let me know the results.
Jan 20, 2021 at 12:06 PM
RHUMMEL73
I had a friend do a load test and it turns out the battery is failing. I will be getting a new battery today. Thanks for your help.
Jan 20, 2021 at 6:08 PM
  • 110,248 POSTS
You are very welcome. Let me know if it starts with the new battery. If it does, I just want to make sure the charging system is working and isn't what caused the old battery to fail.
Jan 21, 2021 at 10:30 AM
RHUMMEL73
It started fine with new battery and seems to be running fine.
Jan 21, 2021 at 7:24 PM
  • 110,248 POSTS
Excellent!!! Pay attention to the alternator gauge in the vehicle. If it is normal, then things sound good. If it seems low, I want you to perform this simple test and let me know the results.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Let me know if you run into trouble. Also, please feel free to come back any time in the future if you need help or have questions. You are always welcome.
Jan 22, 2021 at 5:30 AM
RHUMMEL73
I will and thank you!
Jan 22, 2021 at 5:31 AM
  • 110,248 POSTS
Jan 22, 2021 at 5:38 AM
