engine will not run
1993 JAGUAR
160,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
TERRY T SMITH
not firing, new spark plugs, distributor cap, rotary button. ignition coil getting fire but not firing. so change it out still doing the same.
May 16, 2017 at 6:36 AM
  • 55,770 POSTS
Lets start with checking for spark from the ignition system. Here is a couple guide that we help you get going in the right direction then we can continue.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 19, 2017 at 4:45 AM
