I installed an aftermarket stereo in the center and now it will not crank. Is this something that needs to jumper to make it crank?
Oct 22, 2017 at 7:30 AM
HARRY P
✓Experienced Mechanic
Did you cut any wires or did you have a wiring harness adapter to work with? You might go ahead and check your fuses. It is pretty easy to blow one when working in there.
Oct 22, 2017 at 7:53 AM
Here is guide that will help us see what's going on.
