Will not continue to run
130,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
GLENN GILBERT
  • 44 POSTS
My son was driving down the road the other day and the car just quit running. When he tried to start it he said it would run for a couple of seconds, backfire, and then shut off. He tried to pull the codes but no code showed up. Since I have not seen the car, this is a police interceptor, I told him it sounds like a crank sensor, but I may be wrong. The vehicle does not have a distributor, just coil packs. What would you think might be the problem?
May 5, 2018 at 9:20 PM
Good morning.
Yes, it could be, but the backfire is the key. If it was a crank sensor there would be no spark. A backfire is an indication of backfiring which requires spark. Also, it would code 335.
It sounds more like a failing fuel pump. Low or no fuel pressure will cause this and there is no code for fuel pump failure. You need to check the pressure. There should be a schraeder valve on the fuel rail.
May 6, 2018 at 12:10 AM
GLENN GILBERT
  • 44 POSTS
I spoke with my son in Florida and he said that the car is getting plenty of fuel, in fact when he depressed the schraeder valve it shot a stream of fuel six to seven inches in the air. Would that still be a faulty fuel pump? I was thinking that the timing chain might have slipped a tooth as he says when he gets it started for a second or two the car will shake very badly then shuts off.
Glenn
May 6, 2018 at 7:58 AM
Okay, just depressing the valve does not mean it has enough pressure to work. you need a gauge to verify the pressure.
As far as the timing chain, very possible. You would need a compression test to very. You would have low compression if it is timing.
May 6, 2018 at 8:02 AM
GLENN GILBERT
  • 44 POSTS
What is the normal fuel pressure supposed to be on this vehicle? My son said that he is going to get a fuel pump tester but does not know what the normal pressure is supposed to be.
Thanks
May 6, 2018 at 8:16 PM
Okay, I attached a chart for the fuel pressure.
May 6, 2018 at 8:24 PM
