Will idel but wount runn in drive
140,000 MILES • 5.7L • V6 • 2WD • AUTOMATIC
JONS92
My 92 5.7l Chevy will start about the 4 or 5 try will idel ruff and sometimes die but if I give it any gas or try to drive it it dies and will start back up runs like crap just put a new fuel filter on it the guy I got it from said he ran it out of gas and then it started doing it but after the new fule filter it started right up fine put it in drive got about ten yard it died but act like it was getting to much fule cuz it sit for about ten min and started right back up hit the gas why in park and it died again any help to get me looking in the right way would would help at lot oh got a check engine lift on to going to read the codes tomorrow
Dec 22, 2013 at 10:46 AM
  • 110,251 POSTS
I hate to say it, but I have seen, many times, when people run the tank out of fuel, the fuel pump is damaged and needs replaced. I am interested in knowing the codes you find. However, I feel that if you check the fuel pump pressure, you will find it is low. Check that as well as the codes and let me know what you find.
Dec 22, 2013 at 12:10 PM
