Will crank but will not start?
160,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
KALANIR
I was driving the other day and it started to bog down, so I let off the gas, pressed it again RPMs went up a little then the RPMs went crazy and stalled out. Now it won’t start but it cranks.
I’ve checked the relays/fuses.
Fuel pump is turning on/ fuel pressure good.
Battery.
Spark plugs/cord/ distribution box.
Apr 2, 2023 at 8:18 AM
  • 110,248 POSTS
In most cases, a crank no start condition is the result of either a fuel loss or ignition spark loss issue.
Do me a favor. See if it will start with starting fluid. If it does and then stalls, we know it is fuel related. If there is no change, we need to check for an ignition spark at the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Apr 2, 2023 at 2:52 PM
KALANIR
I replaced the crank shaft sensor, nothing.
But I sprayed some starter fluid in n there, cranked right up.
Apr 3, 2023 at 2:06 AM
KALANIR
It stays on too and turn the key off and on drove it down the block 2 times.
Apr 3, 2023 at 2:07 AM
  • 110,248 POSTS
Did you use the starting fluid after the new CKP sensor was installed or did you try it prior? I ask because if you did, then I don't know if the CKP was bad prior.
However, if it started with starting fluid, that tells me there is a fuel-related issue. At this time, is it operating normally?
Apr 3, 2023 at 1:30 PM
KALANIR
It is working normally and I tried to crank it two separate time before I used starter fluid.
Apr 3, 2023 at 11:13 PM
  • 110,248 POSTS
That is good news. Thanks for the update.
Please feel free to return anytime in the future if you have questions.
Apr 4, 2023 at 12:15 PM
