Engine swap
100,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
JLSAMPLEA67
Will a 2010 Dodge Avenger 2.7 front wheel drive engine fit in a 2007 Chrysler 300 2 7 rear wheel drive? I need to know if I can put it on its side and it work?
Jan 8, 2020 at 5:39 PM
Good morning,
The blocks are the same. You would have to strip down the donor motor to a long block and change over all the parts from the 2007 to the donor block for it to work.
Jan 8, 2020 at 6:35 PM
