Welcome to 2CarPros. Does it have stock tires and rims on it? Any other handling issues with it? If you rotate the steering wheel fully from one side to the other how many turns does it take? Is this something that just started happening or has it gradually gotten worse?
Any noises or clunking while turning?
There really isn't a lot that can cause it to act that way, at least not to both sides. A failed steering rack or steering rack mounts that are allowing it to move are about the only things. Other than having different tires or rims that are limiting the turning radius.
Aug 3, 2019 at 1:24 AM
