Crank no start issue
125,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JBENZ2679
  • 23 POSTS
I have spark and fuel to the rail turns over but won't start.
Jun 2, 2021 at 10:47 AM
  • 110,248 POSTS
A crank no start can be a couple of things. The idea that you checked for spark and fuel indicates to me you certainly have a good idea of the possible causes.
First, is the fuel pressure within the manufacturer's specs? I attached the specifications in pic 1 below. If you haven't confirmed that, do so. Here is a link that explains how to check fuel pressure:
If the pressure is within the manufacturer's specs, I need you to try something. See if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is a fuel-related issue. At that point, we will need to check for an injector pulse to see why fuel isn't entering the engine.sHere is a link that explains how to test for an injector pulse:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Start with this and let me know the results. Also, if it is possible, record the engine cranking and upload it for me to hear.
Jun 2, 2021 at 12:41 PM
