Backfires, will not stay running?
200 MILES • 4.7L • V6 • 4WD • AUTOMATIC
MATTHEW TIBBETT
Acting like it's out of timing backfires won't stay running seems to fight a compression stroke.
Feb 17, 2023 at 9:54 PM
  • 110,248 POSTS
Have you checked for diagnostic trouble codes? This vehicle has an OBD1 system that doesn't require a scanner to get codes.
Here is a link showing how to retrieve codes:
https://www.2carpros.com/articles/odb1-isuzu-1985-1994-cars-and-trucks-code-retrieval-procedure-and-definition
Now, the engine should be a 3.2L if it is a V6. So, please confirm the engine size for me.
Do me a favor, there are several things that can cause an engine to backfire. Take a look at this link and see if anything helps:
https://www.2carpros.com/articles/engine-backfires-while-running
Also, if you feel it could be a timing issue, record it cranking and upload it for me to hear.
I'll watch for your reply.
Feb 18, 2023 at 1:07 PM
