Steering wheel locks
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
IMOGENE.SUMMERLIN
Just put new alternator and battery in, now the steering wheel will lock up when you put in drive. but, you can turn it off and start it back and it works. Then it gets to where it has no power steering at all. sometimes to and head lights get real dim or goes completely out.
Jan 24, 2018 at 11:15 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked the battery voltage at the battery with it running? Sounds like it is not charging properly.
Jan 24, 2018 at 11:56 PM
IMOGENE.SUMMERLIN
I am wondering if the ground for putting a new alternator on has come lose. would it make the steering wheel lock while in drive?
Jan 24, 2018 at 11:59 PM
SATURNTECH9
  • 30,869 POSTS
Yes, it is electric steering.
Jan 25, 2018 at 12:12 AM
  • 55,658 POSTS
I would make sure all the wires and ground wires are connected. If so it sounds like you have had a voltage surge? can I ask if the car was jumped?
Jan 25, 2018 at 8:15 AM
