engine overheating
144,000 MILES • 2.2L • 2WD • AUTOMATIC
TREY MACK
My temperature gauges do not move at all. I am sure the AC drop line is clogged and my TCU is going out because it leaks onto it in the passenger side under my dash onto the floor where the TCU is. also, power steering seems to be going out. The engine will overheat and cut off
Feb 3, 2017 at 5:54 AM
HMAC300
  • 48,601 POSTS
check fuses for gauges then check to see if power at senders might be a bad cluster though which are rebuildable. fill coolant and pressure check for a head gasket leak. and use coat hanger to unclog drain from under car.
Feb 3, 2017 at 10:00 PM
