When attempting to accelerate there is engine hesitation, why?
78,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
BENITOV0415
  • 6 POSTS
The car drives fine when I don’t get on it. Once I try to give it a little more gas, then it seems to be hesitant around 3,000-4,000 RPMs. No check engine light. The exhaust has a little rattle when I start moving then it goes away.
I’ve changed oil, and spark plugs.
The boost seems to be fine.
Jul 19, 2023 at 2:29 PM
  • 110,246 POSTS
The exhaust rattle got my attention. Do you know if it is a simple heat shield, or does it come from the internal portion of the catalytic converter?
I ask because the inside of the converter can come loose and move around restricting airflow. If that is what is happening, you certainly could feel a power loss.
Take a look at this link:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Take a rubber mallet and tap the exhaust to see if you can recreate the sound. This will help pinpoint where it's coming from and if it could be the inside of a catalytic converter.
Let me know
Jul 20, 2023 at 12:37 PM
