Coolant leaking from underneath the SUV
BENAE REED
  • 2001 CHEVROLET SUBURBAN
  • 4WD
  • 198,000 MILES
Coolant is leaking from underneath the car, from the passenger and driver side. When I pour the coolant it does not leak out, but once truck run hot, coolant is then released from under the truck.
Monday, August 26th, 2019 AT 2:14 PM
  • 52,797 POSTS
Good evening.
You need to have a pressure test done to determine the source of the leak.
https://www.2carpros.com/articles/radiator-pressure-test
It could come from so many places. The pressure test will narrow the area so we can help.
Monday, August 26th, 2019 AT 3:16 PM
