Ignition switch will not turn into the lock position
156,176 MILES • 1.9L • 2WD • AUTOMATIC
SATANA
When I bought the car the owner told me that I have to put the parking brake on to keep it from rolling. Well after looking the car over and doing some research I realized that the ignition switch does not turn all the way to the locking position. I tried to wiggle it and also noticed that if you turn it off and back on you have to pull the key out and put it back in. To make it turn over. Plus I can pull the key out in any position. It does not lock into the ignition switch. I am hoping that I can fix the switch and it not be the interlock shifter or trans-axle.
Jul 15, 2018 at 8:50 AM
SATANA
I found the problem. There is a recall on the park lock cable assembly. It was improperly adjusted.
Jul 15, 2018 at 3:31 PM
RENEE L
  • 1,260 POSTS
Hello SATANA,
So happy to read that you found the problem. Thank you for posting the solution, it will help others experiencing the same issue.
Thank you for using 2CarPros.com.
Have a great rest of your day!
Renee
Admin
Jul 16, 2018 at 4:43 AM
SATANA
Unfortunately the recall is for certain VIN's only. And mine does not match. Even though same year, make, and model. And problem. At least I know what could be wrong.
Jul 17, 2018 at 4:32 AM
