Okay, I am a huge Mercedes fan and loyal as can be to the brand. I have had ten Mercedes models in my time. It is number ten that is giving me such heartache.
I bought this car AMG Edition from a couple months ago. The key was broken in the ignition. She handed me a tumbler and key from O'Reillys that she intended to install. I drilled out the old key and installed the new one which also broke.
I went and installed a push button and toggle switch to try and bypass the immobilizer but that did not work. It just cranked and cranked. I installed a crank position sensor and fuel filter and still no turn over. So I ended up getting a steering lock ignition switch from a 1976 Mercedes at the local salvage yard that still had the original keys. It looks and works great except, still no turn over.
I then noticed the key fob had no power. My brother (master mechanic but is busy with his life so I do not ask him much ) looked at it and saw a burn mark. He took the key home and four days later, when I got it back, when I pushed the button, red light came on (only on the key fob though).
How can I ever get this car to drive again? I think no spark, but could there be something else wrong causing this. Please help!
Apr 9, 2018 at 4:31 PM
