Why doesn't my car crank or turn on?
200,000 MILES • 2.3L • 4 CYL • FWD • MANUAL
DAV16MED
My Honda accord I changed the clutch on it so I took out the tranny and installed I put the car back together including wire harness connectors and battery is new. The car get power my headlights and door lights dashboard gets power when I turn the key to turn on the car all I hear is a clicking noise coming from the ecu or fuse box and when I turn the key the engine don't make a sound but the fans turn on what should I do.
Dec 28, 2015 at 7:44 AM
WRENCHTECH
  • 20,758 POSTS
Go back over all your work and look for wires not plugged in or disconnected from where they should be attached. Make sure your clutch switch is still in tact and connected properly.
Dec 28, 2015 at 8:10 AM
DAV16MED
I went back to all connectors I disconnected there all in place do u know where I can get a diagram or something to tell me the wire harness plugs locations so I can triple check all connectors are where there suppose to be the engine don't even try to cranck or anything.. Do u think then ing fuse 1 50 a fld in the engine fuse box can course it not to turn on??
Dec 28, 2015 at 8:16 AM
WRENCHTECH
  • 20,758 POSTS
They don't make a diagram like that. Electrical diagrams are schematics that look like road maps.
You should check all your fuses with a test light with the key on.
Dec 28, 2015 at 8:24 AM
