Why does the engine sputter?
155,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
MATT224
When it is in park, it's fine runs good. When put it in any gear the engine sputters. Messed with electrical plug on side of transmission drove fine till I hit a bump. I tried to do the same thing with no luck. Before all this started, it ran great until I hit a bump then the trouble started. Pictured is what I messed with.
Jan 28, 2023 at 6:31 AM
  • 55,553 POSTS
This is common when the spark plugs, plug wires and coils need to be replaced. Here is a video to show you how to fix the problem which is done on a similar engine, but the procedure is the same and I have provided the instructions for your engine in the images below.
https://youtu.be/e68QXyBAiZo
RH Original Spark Plug Type .................... AGRF22PG
LH Original Spark Plug Type .................... AGRF22P
New Spark Plug Type (Either Side) .................... AGSF22PP
20 Nm (15 lb-ft)
Check out the images (below). Please let us know if you need anything else to get the problem fixed
Jan 29, 2023 at 5:46 AM
