Why does the engine run evenly and smooth on lean mixture on carburator engine?
1990 OPEL CORSA
XCHCUI
  • 91 POSTS
Hello.
This question related to engine with carburator.
I would like to understand why the engine run evenly and smooth when the air/fuel mixture is lean?
I understand why the engine run evenly and smooth while the mixture is rich and why the engine run rough with too rich mixture,but i don't understand why when go from rich mixture(while the engine run evenly)to the 1:14.7 fuel/air ratio,the engine start to run rough(~ 1 lambda),but if we pass the 1:14.7 ratio into the beginning of the lean mixture area,the engine start to run evenly and smooth again?
What is happening ?
Thanks in advance.
May 23, 2015 at 12:08 AM
CJ MEDEVAC
  • 11,004 POSTS
THIS HERE HAS HELPED ME MORE THAN ANYTHING IN GETTING MY CARB RIGHT. HE EXPLAINS JETTING/ POWER VALVE SELECTION/ ETC
YOU MAY HAVE TO COPY AND PASTE IT TO A NEW TAB
http://www.bob2000.com/carb.htm
HERE'S MORE SHOWING MY SET-UP/ YOU WILL SEE PICS OF MY O2 SENSOR WHICH RUNS MY AIR/ FUEL GAUGE
https://www.2carpros.com/questions/1980-jeep-cj7-new-fuel-tank-sending-unit-dash-gauge-wiring-checked-out-good-gas
THE MEDIC
May 23, 2015 at 10:52 AM
XCHCUI
  • 91 POSTS
Thanks,CJ MEDEVAC,for the links,but nothing there explains or deal with the theory:why does the engine run evenly with rich(lambda<1,but not too rich),why the engine is not run evenly when i decrease the a mount of the fuel to get a mixture of 1 lambda,while when i decrease more the amount of fuel,to get a lean mixture(lambda>1,but not too lean)the engine,suddenly,run evenly again.
What is the theory behind that?
I read tens article about the subject,as you attached,but didn't find a good explanations,besides the fact that this is what happens.
Thanks in advance.
May 23, 2015 at 8:05 PM
CJ MEDEVAC
  • 11,004 POSTS
I RECKON YOU'RE GETTING SORTA TOO SCIENTIFIC FOR ME!
THIS OTHER LINK IS PROBABLY AS FAR AS I CAN TAKE YOU, MOST OF IT IS OVER MY HEAD, YOU'VE PROBABLY GANDERED OVER IT ALREADY!
http://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
OUT OF CURIOSITY, 'ZACKLY WHAT ARE YOU DOING, AND WHAT END RESULT ARE YOU AFTER?
THE MEDIC
May 24, 2015 at 12:15 PM
