Rear brake does not totally release
170,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
NATHAN SLABAUGH
  • 9 POSTS
I just changed my brake pads and rotor on my rear wheel (left). Since the brake was still not releasing, I changed the flexible brake hose next to the caliber. This might have helped a little, but they are still dragging. Is there another hose that might have collapsed, or should I try something else? The rear right side is fine.
Jul 2, 2018 at 10:52 AM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com.
If the caliper piston is free and releasing, the slid pins are free and lubricated, the only other thing is the pads are too tight in the caliper mount itself. What I have seen most often is this. The brake pads freeze in place and require a hammer to remove them. Once out, I find the hardware which the pads sit in has been bent inward toward the pad due to rust on the mounting bracket. What I always do is this: Remove hardware, remove caliper mount (Which is the component that holds the pads) then I take a file and remove all rust from the mount where the brake hardware is to be installed. When the pads are then installed into the mounting bracket, they are easy to move.
Also, make sure the caliper piston is releasing. If in fact, the pads are loose, the slid pins are working. Try this test: Safely lift the rear of the vehicle and support it. Have a helper apply the brakes so you cannot turn the tire. Then, have the helper release the brakes. The wheel should turn easily. If that is not the case, then suspect the caliper piston is not operating as designed. Since you already replaced the rubber hoses, they should not be an issue.
Honestly, either the pads are too tight in the mount, the slid pins are not free, or the caliper piston is sticking.
Here are general directions for installing rear pads. Make sure you did not miss anything:
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
I attached a couple pictures for your review. The second picture shows the guide pins. I hope this helps. Let me know if you have other questions.
Jul 2, 2018 at 12:28 PM
NATHAN SLABAUGH
  • 9 POSTS
Thanks for that information, the pads seem to slide nicely in the mount, and the guide pins are sliding and lubricated. Is there a good way to test the piston, and is there a fix? To remove the caliper and mount, I had to use a pry bar to get it off the rotor.
Jul 20, 2018 at 10:00 AM
When you say you had to pry it off the rotor, is that with the new pads and rotor or the old ones?
Jul 23, 2018 at 8:36 AM
NATHAN SLABAUGH
  • 9 POSTS
That was the new ones.
Jul 28, 2018 at 2:55 AM
You should not have to do this.
Does the piston pry back easily in the caliper?
Jul 28, 2018 at 10:43 PM
NATHAN SLABAUGH
  • 9 POSTS
No, using a big C-clamp I can force it back, but it is not "easily". Is there a fix for this or do I need a new caliper?
Jul 30, 2018 at 11:34 AM
Try cracking the bleeder loose and see if it moves freely.
Jul 30, 2018 at 8:06 PM
NATHAN SLABAUGH
  • 9 POSTS
I cannot budge the bleeder, it lost its plastic cover and I think it is rusted as well.
Jul 31, 2018 at 8:09 AM
Okay, I would replace the caliper.
I suggest replacing both sides as they should be changed in pairs.
Jul 31, 2018 at 8:12 AM
