Why does my car shifter not stay in park?
300,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SHERWIN SUBBIAH
My car does not stay in park and drive does not light up on the inside cluster but engages R.2.L if you put it in the it stays in one gear.
Mar 26, 2025 at 9:38 PM
  • 55,684 POSTS
It sounds like you have a shift cable that is broken or stretched. I would remove the shift cable and work the selector lever on the transmission by hand, I have also seen the neutral safety switch go bad and jam up. So, this can be the issue, as well. You should be able to tell once the shift cable is removed from the transmission.
This video should help:
https://www.youtube.com/watch?v=UtMsbNzquCk
Please go over this guide and get back to us.
Mar 27, 2025 at 4:29 AM
