I just bought this car. Needed a timing set. Replaced idler, tension-er, water pump, belt, triple checked timing marks if not more. New plugs, wires, coil. Checked all the fuses. Made sure all wires are plugged in. Vacuum lines are good. New battery. Has good fire to the plugs. Firing order is correct. Car turns over, but it will not start. Will not even try. Have I overlooked something? Did I not do something right?
SPONSORED LINKS
Monday, March 5th, 2018 AT 8:38 AM
