both turn signals stopped working after replacing one bulb
1,954,516 MILES • 0.9L • 4 CYL
LESLIE ROGERS
Turn signals not working or lighting up after i replaced bulb in one.
May 12, 2017 at 9:46 PM
HMAC300
  • 48,601 POSTS
if they worked before then the bulb may be in backwards/not all the way or the wrong one. If they did not work prior have a mechanic check because it may be a hazard switch. also, check fuses under hood and in dash.
May 12, 2017 at 11:20 PM
