No sound when turning the key to start the van
175,000 MILES • 3.0L • 6 CYL
OMAR200679
  • 6 POSTS
Hey guys, I changed my starter, the ignition switch, and got a new battery. I can turn the key and still get nothing, but the light on the dashboard comes on. I can jump it by the starter relay fuse, but it only turns over like it wants to start.
Mar 17, 2019 at 6:58 PM
JOETECHPRO
  • 705 POSTS
Hey OMAR200679,
When you are jumping the starter relay fuse and the starter is turning the engine over have you got the ignition switched on - dash lights on?
Have any of the parts you replaced made any changes to the fault?
Regards, Joe
Mar 18, 2019 at 10:43 AM
OMAR200679
  • 6 POSTS
Yes, I do and when I turn the key the fuel pump does not come on or nothing.
Mar 18, 2019 at 10:50 AM
OMAR200679
  • 6 POSTS
I do not know what to do next.
JOETECHPRO
  • 705 POSTS
Hey OMAR200679,
It seems like you have a power distribution problem.
Can you please check all fuses in the under hood fuse box?
The link below shows how to visually check the fuse is in tact and test for power to both sides of the fuse with a test light.
Some of the fuses will only have power with the ignition on.
Which fuse have you been jumping to get the engine to crank?
Let me know how you get on or if you have any further questions
Regards, Joe
Mar 18, 2019 at 11:33 AM
OMAR200679
  • 6 POSTS
I just the starter relay fuse when I just it off it turns the motor over but it wont start it. I was just checking to see if the starter was bad, but the fuel pump don’t hum when I switch the key on. so I check and changed. what I thought it could be?
Mar 20, 2019 at 5:11 AM
JOETECHPRO
  • 705 POSTS
Hey SHUGHES013,
Have you checked all fuses in the under hood fuse box?
What are you jumping when you get it to turn over?
Attach a photo if possible.
If it cranks when jumped you do not have a starter problem.
You will need to be clearer if i am to point you in the right direction.
How did the fault occur originally?
Did the vehicle cut out and the not start or just not start after shut down?
Regards, Joe
Mar 20, 2019 at 8:08 AM
OMAR200679
  • 6 POSTS
It had the battery light on the dash it stayed on so I took it to get an inspection done on it and then the guy had one of his mechanics look at it. then when I went to get it and the guy said he can’t get it to start by the key. so I started replacing the parts that I thought he may have messed up. but I have not checked the fuses yet.
Mar 20, 2019 at 8:20 AM
JOETECHPRO
  • 705 POSTS
Hey OMAR200679,
Did the mechanic replace anything?
You need to check the fuses before we go any further and let me know what you find.
Regards, Joe
Mar 20, 2019 at 8:29 AM
OMAR200679
  • 6 POSTS
I have checked them an they are good. when I turn the key all I get is a clicking sound from the fuse box and the lights go off when I turn the key so I put the cables on it and it still do the same.
Mar 21, 2019 at 3:57 PM
OMAR200679
  • 6 POSTS
Hey just been waiting to hear back from you to see what you think I should do next.
Mar 22, 2019 at 4:41 PM
  • 55,628 POSTS
Is the security light flashing when you try to crank it over? If so here is a guide to help you reset the system if not here is a guide and the starter wiring diagrams so you can see how the system works:
https://www.2carpros.com/articles/how-to-reset-a-security-system
and
Mar 23, 2019 at 7:13 AM
