Fill plug for the transmission and camshaft position sensor location
81,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ACEANDSHURNA
What type of transmission fluid do i need and where and how do i add it?
Jul 19, 2019 at 1:36 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Here are the directions. The attached pics correlate with the directions.
__________________________________
2004 Suzuki Forenza L4-2.0L
Transaxle Fluid Level Checking Procedure
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Service and Repair Procedures Transaxle Fluid Level Checking Procedure
TRANSAXLE FLUID LEVEL CHECKING PROCEDURE
Tools Required: DW260-070 Plug Remover/Installer
pic 1
1. Start the engine and allow the engine to idle for approximately 5 minutes, or, if possible, drive the vehicle for a few kilometers(miles) to warm the transaxle fluid. Check the fluid level when the transaxle is over 30°C (86°F).
pic 2
2. Press the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the park position. (Left-Hand Drive Shown, Right-Hand Drive Similar.)
3. Raise and suitably support the vehicle.
4. Place a fluid container below the fluid level plug.
pic 3
5. Remove the fluid level plug using the plug remover/installer DW260-070. Because the transaxle operates correctly over a range of levels, fluid may or may not drain out of the plug hole when the plug is removed.
pic 4
6. Check the oil fluid level. If fluid does not drain through the plug hole after adding a total of 4 liters, then the transaxle was either underfilled or the transaxle is leaking fluid. Inspect the transaxle for fluid leaks. Fix any leaks before setting the transaxle fluid level.
7. Install the fluid level plug using the plug remover/installer DW260-070.
^ Tighten the Plug to 45 Nm (33 ft. lbs.).
pic 5
8. When the fluid level checking procedure is completed, wipe any fluid from the transaxle case with a rag or shop towel. Also, check that the fluid fill cap and the vent tube are properly installed lied.
___________________________________________
Here are the fluid type used. There are multi purpose fluids available. Just make sure this type is covered.
FLUID TYPES
Automatic Transmission Fluid Type
Type .................... Esso LT71141 or Total ATF H50235
Let me know if this helps.
Jul 20, 2019 at 3:24 PM
