White smoke, rough idle and excessive fuel consumption
170,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JOSS O MAPHUTI
White smoke when i start the engine and when turning off.
Jan 2, 2019 at 6:12 AM
Good evening,
White smoke is an indication of a coolant burning in a cylinder. this is usually a result of a failed head gasket leaking coolant into a cylinder.
You will need to have a shop check out the engine for a failed head gasket. they need to do a leak down test on each cylinder to see if a gasket has failed.
that would also explain the rough running and increased fuel usage.
Jan 2, 2019 at 9:36 AM
