When accelerating turbos making noise and white smoke pouring out exhaust, code P1335
180 MILES • 6.4L • V8 • TURBO • 4WD • AUTOMATIC
JOSEPHBEST23
  • 7 POSTS
So Friday afternoon while driving home my check engine light came on and threw a p1335 EGR valve code. But the truck ran fine. So the next morning I decided to take a short drive to the trash dump and see if it had any issues. While accelerating and kicking on the turbos, a very noticeable screaming sound came from the turbos every time I went into the gas pedal and also a very heavy white smoke would pour out the exhaust. So heavy the cars behind me were blinded. I got it home and it cut itself off when I got down to like 5 mph, which I think it does when it detects an issue. After waiting an hour it cranked back up but the whining for turbos and smoke still persist.. The turbos have it's own coolant system/reservoir and the level has gone down but it's not empty. I've always been told heavy smoke means coolant leak, but why is the turbo making that fuss? And the EGR system is something I know nothing about. So I just wanted to get your opinions/knowledge before I take it somewhere.
Jan 1, 2020 at 9:55 PM
Good afternoon,
The most common cause is the EGR cooler. When it leaks, coolant gets into the exhaust and cause the engine to smoke white.
Can I have the complete VIN so I can find out whether you have a vertical or horizontal cooler?
Jan 2, 2020 at 4:35 AM
JOSEPHBEST23
  • 7 POSTS
It's vertical. but would that cause the turbo to whine?
Jan 3, 2020 at 1:23 AM
No, but the coolant passing through the turbo would cause it. It is thinning out the oil.
Jan 3, 2020 at 3:17 AM
JOSEPHBEST23
  • 7 POSTS
Okay, thanks. I hope that wouldn't be an automatic turbo change?
Jan 3, 2020 at 3:47 AM
Pretty much. The bearings have been damaged for the water in the system.
Jan 3, 2020 at 4:02 AM
