White smoke with excessive water out muffler
189,000 MILES • 1.3L • 6 CYL • 2WD • AUTOMATIC
BIGMIKE24
White smoke at start up. Went undercarriage and seen a stream of constant water out the muffler right before the tail end small hole in muffler.
Oct 23, 2017 at 11:50 AM
HARRY P
  • 2,292 POSTS
Sounds like you have a blown cylinder head gasket. Check your engine oil. If it is muddy/milky/chocolate milky, then water has seeped into the combustion chambers and also into the oil pan. Usually, this happens after the engine has been overheated. Here is our guide on how to properly check for a blown head gasket: https://www.2carpros.com/articles/head-gasket-blown-test
Hope this information helps.
Oct 23, 2017 at 12:01 PM
BIGMIKE24
Darn, I was afraid someone would say that. Yes everything you explained on what it might look like is all correct. Thanks
Oct 23, 2017 at 5:16 PM
  • 55,649 POSTS
Nice work HEYMAN1104
Cheers, Ken
Oct 25, 2017 at 10:22 AM
