White smoke that smells like burning plastic
85,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
OSCARTORRES424
  • 5 POSTS
Everyday as soon as I start my car white smoke appears on the left corner of the engine bay. I haven't really noticed a significant drop in my oil level. The smell of the smoke is similar to burning plastic. I also haven't really noticed an obvious oil leak. My antifreeze level is right where it need to be. I am trying to gather knowledge in regards to this problem to avoid taking it to an outrageously expensive BMW repair shop. Any help/suggestions will be much appreciated!!!
Oct 23, 2014 at 2:46 AM
  • 110,248 POSTS
How much smoke? Are there any exhaust leaks? Is this only when started or does it continue after the engine is running?
Oct 23, 2014 at 3:40 AM
OSCARTORRES424
  • 5 POSTS
Thank you for your response, my friend and I have fixed the problem. The problem was that I had an engine oil leak that was landing on the exhaust manifold which caused tons of smoke. The reason it was leaking was because the valve cover gasket was completely toasted. I have now replaced it and have no issues with the white smoke. I appreciate your help!
Oct 30, 2014 at 12:53 AM
  • 110,248 POSTS
Glad you got it fixed. Let me know if you have questions in the future.
Oct 30, 2014 at 1:43 AM
