White smoke from exhaust during beginning of start
81,250 MILES • 1.3L • 4 CYL • 2WD • MANUAL
PRAKASH P MESTHA
My car is emitting white smoke during beginning of start. recently have done stem seal, piston rings, timing belt , gasket, air filter replacement. Also done throttle body cleaning. unable to clear O2 sensor error (mechanic told for replacement) and oil level is going down considerably. please advice, whether i have to do any diagnostics on the vehicle.
Nov 22, 2016 at 6:36 PM
  • 31,937 POSTS
White smoke is often coolant being burnt, do you have to top up the engine coolant ata all?
Nov 22, 2016 at 6:51 PM
PRAKASH P MESTHA
but there is a drop in engine oil level, ( coolant level not changed).
Nov 22, 2016 at 7:01 PM
  • 31,937 POSTS
engine oil will burn with a bluish color, if oil consumption is high, you can start with compression test dry first and then wet, that is with a small amount of oil in the cylinder to temporary seal the rings, if the comps come up considerably you may have a ring not sealing do this test first.
Nov 22, 2016 at 7:08 PM
PRAKASH P MESTHA
had done compression test before to repair, it was 12.7. (range 13). bore surface is good as per mechanic. also replaced with new rings.
Smoke color is actually bluish white.
Nov 22, 2016 at 7:36 PM
  • 31,937 POSTS
If you are using full synthic oil rings will not bed in and this will cause oil consumption
Nov 23, 2016 at 3:57 AM
PRAKASH P MESTHA
im using servo 20w40 oil and after rings replacemen, car has done 1500kms,
Will it take somemore time for bedding? or should i change the oil grade.?
Nov 23, 2016 at 2:53 PM
JOHNNY G.JR
  • 320 POSTS
Straight 30 wt.conventional should work
Nov 24, 2016 at 11:40 AM
  • 55,691 POSTS
If the cylinders have not been remachined the rings will never seat. A rebuilt engine should always have the cylinders bored no matter how many miles are on the block.
Best, Ken
Nov 26, 2016 at 12:12 PM
