White smoke coming from tail pipe exhaust?
210,000 MILES • 2.5L • 2WD • AUTOMATIC
DREW CARBAJAL
I rolled over a high-speed bump in a hotel parking lot and now there's white smoke coming from my tail pipe. I hit it kind of hard. When I run the A/C it tends to smoke the most and I'm not sure why.
Sep 16, 2022 at 4:15 PM
  • 55,781 POSTS
It sounds like you blew a head gasket which can happen when the engine is jarred, or it was just a coincidence. To be sure let's go over this guide to confirm the failure. If it does have a blown gasket the cylinder head will need to be removed and the gasket replaced, but I have seen people use blue devil which works in some cases.
Here is a video to show you how to use it as well:
https://youtu.be/Xi41RFMP8Ow
and
Please go over these guides and report back.
Sep 17, 2022 at 3:39 AM
