White smoke coming from hood, says check oil
150,000 MILES • 4 CYL • AUTOMATIC
DAYRAH YELLOWFISH-ELIZONDO
My car was driving fine and then my temperature gauge said hot and so I stopped and opened the hood. It looked like smoke was coming out from where the oil was. I checked my oil and then put some more and the levels were fine. I drove slow to my destination and then parked the car and let it sit overnight. I added antifreeze, and tried to start it in the morning but it would not start. I just recently purchased this car about four days ago and the mechanic said it was good to go. I do not know what the issue is. Any help/ information is greatly appreciated.
Oct 17, 2016 at 1:33 PM
WRENCHTECH
  • 20,760 POSTS
It sounds like you may have blown a hose or something to start with that probably could have been repaired reasonably cheap but after driving it home you could have very serious internal damage now.
Oct 17, 2016 at 9:09 PM
RENEE L
  • 1,260 POSTS
Hi DAYRAH,
Remove all of the spark plugs and see if the engine will crank over, if not then check your battery and starter.
Also, here is a link to an informative article from this site with step by step instructions and pictures and a video on what to check for when your vehicle will not start.
If you need any further help please come back to the site as we are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Oct 18, 2016 at 5:48 AM
