Blown head gasket?
208,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ERICAMOORE1967
I flushed my radiator out and had to cut the heater core cords and connected them together to bypass the heater core. Now I have white smoke and water coming out my exhaust and it doesn't go away.
Dec 30, 2020 at 9:35 AM
I can understand the confusion because these things would not cause the engine to start burning coolant which is what we are dealing with. Here is a guide on this issue that will help:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
However I suspect we need to start at the beginning and make sure the head gasket is not blown because these things alone would not cause this. Here is a guide on how to do this:
Let's run through this material and we can go from there. Thanks
Dec 31, 2020 at 9:28 AM
